Kathy:
We noticed this problem too quite some time ago and we were told by support
that the system doesn't look past 100 transactions, so you could very likely
see that they don't add up - prior to 100 records. It can be a problem if
you are trying to track a problem using the running totals, but it
straightens out from that point forward.
HTH.
Julie
Mercury Minnesota Inc.
HTH.
Julie
----- Original Message -----
To: "Vantage Onelist (E-mail)" <Vantage@...>
Sent: Friday, June 17, 2005 12:30 PM
Subject: [Vantage] Running Totals for Inventory
> We are currently on Ver 5.2, and have been using Vantage since 1998.
> Just recently we have started to scrutinize the part transaction data.
> I have found that many of our part numbers have incorrect running totals
> with the first ever transaction. For example when looking at the
> transactions for part ABC, the very first transaction happened on
> 06/20/98, it was a MFG-STK transaction for 33 pcs. So you would think
> that the running total would be 33, but it is not it is some other
> number, for some parts it is higher, and for others it is a negative
> number. It is causing problems with a report that I I created for aging
> inventory, because the report does not pick up the phantom balance the
> very first transaction is being calculated with. Has anyone else seen
> this?
> Kathy Hambleton
> Electron Energy Corporation
> 717-898-2294
> 717-898-0660 (fax)
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
