Sales Order Acknowledgement and taxes
Hi
There is two major places in Epicor where you can put taxes on or not. You
must check those place before trying to make a different sales order report.
1- In the customer, you have the tax tab where you have to put yours
(for example, for different customers, of different country, I set exempt
or quebec....)
2- In the sales order, in the release, you have the tax release that
must be set to your taxes rates.
If those two things are great, you should see the taxes on the sales order.
If you don�t see the fields at all on the sales order acknowledgment, then
you must add them. You first need to go in the report data definition on
the sales order acknowledgment, to see if the fields are included or
excluded from that type of report.
Then, if the fields are included, you generate the xml files of the sales
order acknowledgment, you copy it on your desktop.
You open the file of the sales orders acknowledgment report in crystal
report ( make a copy before changing it...) and you add your fields.
Crystal report will ask you to link your report to the xml file in order to
show you a view before you save. And then, you should have the taxes on
your sales order acknowledgment.
*Am�lie Pelletier*
*Analyste Programmeur / Program analyst*
[image: cid:image001.jpg@01CD5525.2091A820]
*230, Boulevard Nilus-Leclerc*
*L'Islet, Qu�bec (Canada)*
*G0R 2C0*
*T�l�phone: 418-247-3986 ext. 2390*
*Fax: 418-247-7925*
*amelie.pelletier@... <brigitte.savoie@...>*
*P** *Est-ce n�cessaire d�imprimer ce message?
*Please consider the environment before printing this email**.*
The sales order acknowledgement report does not show any taxes from the order either as a separate item (like Miscellaneous Charges) or in the Order total. It does show on the proforma invoice, so I'm sure it's just an omission from the Crystal report. I am posting this here in hopes that some fellow Epicor user adept with crystal has created a version of the sales order acknowledgement to include the taxes.
I added another line to the SOForm in the summary area for tax.
The field is on the OrderHed - OrderHed.DocTotalTax
I modified the @total from ({@MiscTotal} + {@SubTotal} +{@OHMiscTotal})
to ({@MiscTotal} + {@SubTotal} +{@OHMiscTotal} + OrderHed.DocTotalTax})
Where do you print proforma invoices from now. Have not seen this in Epicor
Mark
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of stanchmura
Sent: Wednesday, 14 August 2013 5:52 AM
Subject: [Vantage] Sales Order Acknowledgement and taxes
This email and any attachments to it are confidential and may contain information which is commercially sensitive and/or legally privileged. Unless expressly authorised by the sender, you must not use, disseminate, copy or distribute the information contained in this email. If you are not the intended recipient, you have received this communication in error. In that case, please delete all copies of the email immediately and contact Great Western Manufacturing either by return email or telephone on 07 4636 9120.
We recommend that you scan this email and any attachments for viruses before opening. Great Western Manufacturing does not accept liability for any loss or damage incurred either directly or indirectly from opening this email or any attachments to it.
The proforma is on the Actions menu right under Print Sales Order
Acknowledgement
This communication is intended only for use by the addressee(s) named herein
and may contain technical data as defined in the International Traffic In
Arms Regulations (ITAR) 22 CFR 120.10. or the Export Administration
Regulations. Export of this material is restricted cannot be exported to
foreign persons or foreign destination without prior written approval from
the U. S. Department of State or the US Department of Commerce.
Mark Betts
Sent: Tuesday, August 13, 2013 9:01 PM
Subject: RE: [Vantage] Sales Order Acknowledgement and taxes
Mark
9120.
What version are you on?
Stan Chmura
Sent: Wednesday, August 14, 2013 5:04 AM
Acknowledgement
Behalf Of
Mark Betts
Mark
9120.
9.05.701
Cathy
Sent: Wednesday, August 14, 2013 12:45 PM
Behalf Of
Stan Chmura
Acknowledgement
Behalf Of
Mark Betts
Mark
9120.
