How do I specify the OrderRel#OrderNum, and OrderRel#OrderLine?
To have multiple lines, it looks like I need to include the column OrderDtl#OrderLine
If I set all of them as 0
, I get a new order for each line. Same thing if they are all 1
If I set them as 1, 2, 3, … I get a single order, with multiple lines.
However … If line 2 was a sales kit (say with 11 components), the third row of my DMT file tries to replace the first component of the sales kit specified on line/row 2. Even when the “Update” box is unchecked in DMT.
If I set my OrderDtl#OrderLine values to 1, 2, 15 it works as desired. But this requires that I know the number of components in the sales kit in order to set the line numbers properly.
I can set the OrderDtl#OrderLine values with gaps bigger than the expected max sales kit length, like
1, 21, 41, 61, and that also works.
But when I need to add OrderRel info too, I get stuck.
