Jose,
Thanks for the tip. My earlier post on not seeing an action was when I was
looking at Standard. After my post I tried the In-Transaction and found an
action that worked.
Thanks to both you and John for helping me through this problem.
Mike
Jose Gomez
Sent: Wednesday, July 18, 2012 4:34 PM
Subject: Re: [Vantage] Sales Order Firm Release Default
Are you on 9.05? If so Use a Data Directive this is how I've done it before,
use a data directive on OrderRel and set the field to false if the RowMod
is A
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
action that worked.
Mike
Jose Gomez
is A
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Jul 18, 2012 at 4:31 PM, Mike Numbers <mnumbers@...> wrote:
> John,
> Thanks for responding. I must be missing something. GetNewOrderDtl is
> the start of the new line. Since FirmRelease defaults to Yes on
> OrderRel I need to catch the process after OrderRel is created and
> then change the value to No.
> Mike
> Behalf Of John Driggers
> Sent: Wednesday, July 18, 2012 3:28 PM
> Rather than post processing on update, run it Post Processing on
> GetNewOrderDtl. That should give you the new line (rowmod = 'A') and
> you can adjust fields as you like on that.
> *John Driggers*
> *Chief Data Wrangler*
> *I have an Epicor blog <http://usdoingstuff.com/>. How useful is
> that?*
> *:: 904.404.9233
> :: waffqle@...
> :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> On Wed, Jul 18, 2012 at 2:45 PM, Mike Numbers <mnumbers@...> wrote:
> > I am having problems with creating a BPM for this. My first approach
> > was to create a Post-Processing Method Directive on Salesorder.update.
> > One of my problems is identifying new records. When I add a new line
> > to the order, the RowMod for ttorderdtl and ttOrderRel comes back as
> > blank. Another issue with this is the last line added does not
> > appear to be writing to the database when the process runs.
> > When I looked at a Data Directive for OrderRel, I can see a
> > condition that should let me identify new records, but I don't see
> > an action that allows me to change the value for only the new records.
> > Any help would be appreciated.
> > Mike
> > Sent: Wednesday, July 18, 2012 10:26 AM
> > BPM is going to be the way to go for this one.
> > *John Driggers*
> > that?*
> > *:: 904.404.9233
> > :: waffqle@...
> > On Wed, Jul 18, 2012 at 10:24 AM, mike.numbers <mnumbers@...>
> > wrote:
> > > I have been asked to default all new orders to NOT be Firm Released.
> > > Looking at the data dictionary, OrderRel.FirmRelease defaults to Yes.
> > > Is there a way for me change this default to No? Or should I try
> > > to create a BPM that changes the field to No when the order is
created?
> > > Not sure if I have the ability to change the data dictionary and
> > > if so how to do it or am I in an area I shouldn't be in.
> > > 9.04.507a
> > > TIA
> > > Mike
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > must have already linked your email address to a yahoo id to enable
access.
> > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
