Sanity check for Kinetic row-update
I’m working on two different cloud systems, and in one the established pattern I’ve used for the row-update widget, with an expression that substitutes for empty strings, isn’t working.
The console says the expression has evaluated correctly, but the row doesn’t update.
As an example, “{actionResult.output}” successfully updates the row IF there’s a value returned. If not, the field is literally set to {actionResult.output}. But if I use a conditional expression that evaluates to either the result or a default value, the field doesn’t change at all.
Has a recent update changed that behaviour?
I haven’t seen anything like that, where the unevaluated value “{actionResult.output}” is returned, but the evaluated output is returned if present. I’ve seen some serious inconsistency in App Studio lately. I would probably start by creating an entirely new event from scratch and seeing if the new event behaves the same way.
It would save time if I could be confident that problems were definitely my fault …
App Studio is less inconsistent than it was, I’d like to stress, in the hopes it doesn’t punish me for implying otherwise.
