It's Vantage 8.03.409C
---In vantage@yahoogroups.com, <jckinneman@...> wrote:<humor> Must be due to all the missing semi-colons... <humor>
If you are on E9, you can use the Add UD child wizard to write most of the code and then adjust as needed.
Jim Kinneman
Encompass Solutions.
---In vantage@yahoogroups.com, <kirianno@...> wrote:Hello,
I have added fields on LotNumberEntry that are the same as some fields I added to UD100 and UD100A. They are hooked up to the UD100 Adapter and I can bring data in FROM the UD100 and UD100A just fine. I'm using the Update method but the data never saves BACK to UD100. Can anyone tell me why?
Here is my 'Save' button click event.
Dim UD100Adapter as UD100Adapter = New UD100Adapter(oTrans)
UD100Adapter.BOConnect()
If (UD100Adapter.GetaNewUD100())
Dim irowCount as Integer = UD100Adapter.UD100Data.UD100.Rows.Count
Dim edvUD100Row as DataRow = UD100Adapter.UD100Data.UD100.Rows(irowCount-1)
edvUD100Row.BeginEdit()
edvUD100Row("Key1") = txtDetailJobNum.text
edvUD100Row("Key2") = txtDetailLotNum.text
edvUD100Row("Key3") = String.Empty
edvUD100Row("Key4") = String.Empty
edvUD100Row("Key5") = String.Empty
edvUD100Row.EndEdit()
edvUD100Row.AcceptChanges()
UD100Adapter.Update()
If (UD100Adapter.GetaNewUD100a(txtDetailJobNum.Text, txtDetailLotNum.text, String.Empty, String.Empty, String.Empty ))
Dim irowCountA as Integer = UD100Adapter.UD100Data.UD100A.Rows.Count
Dim edvUD100ARow as DataRow = UD100Adapter.UD100Data.UD100A.Rows(irowCountA-1)
edvUD100ARow.BeginEdit()
edvUD100ARow("ChildKey1") = ucbDefectCodes.value
edvUD100ARow("ChildKey2") = txtCoreOut.text
edvUD100ARow("ChildKey3") = String.Empty
edvUD100ARow("ChildKey4") = String.Empty
edvUD100ARow("ChildKey5") = String.Empty
edvUD100ARow.EndEdit()
edvUD100ARow.AcceptChanges()
End If
End If
UD100Adapter.Dispose()
