I think that's already happening (or I'm still misunderstanding the
difference). There is another method in the script doing this when the
button is clicked:
Private Sub btnCalcWithTax_Click(ByVal Sender As Object, ByVal Args As
System.EventArgs) Handles btnCalcWithTax.Click
oTrans.Update()
oTrans.Refresh()
Dim quoteHed As EpiDataView =
CType(oTrans.EpiDataViews("QuoteHed"),EpiDataView)
'//Get the Tax region from the customer
Dim taxRegionCode As String =
GetTaxRegion(quoteHed.dataview(quoteHed.Row)("CustomerCustID"))
'//Calculate the total of the sales taxes in the region
Dim percentSumOfTaxes As Single = GetSumAllTaxes(taxRegionCode) / 100
quoteHed.dataView(quoteHed.Row)("TotalPotential") = (percentSumOfTaxes
+ 1) * quoteHed.dataView(quoteHed.Row)("TotalPotential")
'//Update the Screen to display the values
quoteHed.Notify(New EpiNotifyArgs(QuoteForm, quoteHed.Row, 0))
End Sub
The values on-screen do update after this method is called.
That was my starting point. After that executes, if I save the entry
at that point, the values get reverted.
button is clicked:
oTrans.Update()
oTrans.Refresh()
End Sub
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> --- In vantage@yahoogroups.com, "steve.thoms" <steve.thoms@> wrote:
> > Forgive me as I'm still learning my way around the Epi framework and
> > how all the objects and methods fit together...I've done a full day
> > worth of searching here (and elsewhere) and experimentation with a
> > little progress but no solution.
> > We have a customization on the Quote Entry screen that correctly
> > updates data in an EpiDataView and displays that on the form (adding
> > tax to Potential and Expected when a button is clicked). When we
> save
> > that entry, however, the data reverts back to the pre-tax
> > value/calculation.
> > I'm somewhat confident I need to use an adapter (QuoteAdapter), get
> > the data associated with the Quote Number I'm working with, manually
> > update the appropriate column values, and update the adapter.
> > What I've tried so far results in a data lock when I save. I get a
> > message indicating "someone else has changed the record and I should
> > refresh and reenter the data".
> > This is the gist of what I've tried so far:
> > Private Sub SaveTaxCalculation()
> > Dim quoteAdapter As QuoteAdapter = New QuoteAdapter(QuoteForm)
> > Dim adapterConnected As Boolean
> > adapterConnected = quoteAdapter.BOConnect()
> > If (adapterConnected) Then
> > quoteAdapter.GetByID(quoteHed.dataView(quoteHed.Row)("QuoteNum"))
> > quoteAdapter.QuoteData.QuoteHed.Rows(0)("TotalPotential") =
> > quoteAdapter.Update()
> > End If
> > quoteAdapter.Dispose()
> > End Sub
> > The values in the adapter data do change (confirmed with MessageBox
> > output) after the assignment. If I leave the Dispose() call in, I
> get
> > the record lock I mentioned. If I take it out, the data reverts back
> > to the pre-tax values.
> > Can anyone tell me if this is even the right direction to be heading
> > or better yet, offer some advice on how to get this working?
> > Thanks everyone...
> > -Steve
> The QuoteEntry Form already has a quote adapter defined. You need to
> update the data in that adapters dataview and notify the dataview
> that you updated some data. When you instantiated a second quote
> adapter it is like two people trying to open the same Excel
> workbook.... only one of them can update...
> bw
