I have a custom dashboard in Kinetic that I have converted in Application Studio. I have made good progress and I wanted to make sure my solution saved my layer. In this solution, the layer I am working on is the only thing being saved. I first set up this solution on 7/18. No matter what I do, the LastUpdated date still shows 7/18 even though I have made several changes to my layer. I have saved and published the layer, but I don’t have any proof that the solution picked up the changes. How do you all save and restore your layers?
I didn’t notice the problem with dates you are mentioning. Maybe because I was not looking at it.
You can always try to build solution, install it in different environment and if you have your changes in place after that you have proof.
