Schedule a Database Conversion
Call Epicor Progress program need setup SHARED VARIABLE. How to setup?
--- In vantage@yahoogroups.com, "cubcrafters_it" <jason.navarrete@...> wrote:
> Something like this might be worth trying in test:
> "C:\epicor\oe102a\bin\prowin32.exe" -db MFGSYS -ld mfgsys -H localhost -S 9400 -N TCP -ininame "C:\epicor\Epicor905\Server\config\Epicor905.ini" -T "C:\epicor\EpicorData" -p "C:\epicor\Epicor905\ClientServer\cv\cvxa0041.r"
> Each of the database conversions list a program .p file, which I'm guessing may reference the files in the cv folder. If it's not an interactive program, the conversion may just run.
> Good luck!
> (Thanks to Jose Gomez for the info on executing Progress files directly)
> --- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@> wrote:
> > I've been told a few times these have to be run manually.
> > I just include it as part of my scheduled maintenance.
> > If you hear differently that would be great.
> > On a related note...
> > I wonder if anybody has identified the conditions leading to stale credit values on the customer tracker?
> > I've seen it happen but I've never been sure what the cause was.
> > --- In vantage@yahoogroups.com, Tony Hughes <thughes281@> wrote:
> > > Anyone know if I can schedule a database conversion to run each evening?
> > > Example, I want the "6430 REcalculate Part On Hand / Allocated" to run each night.
> > > we're on 8.03.409a.
> > > Thanks.
we're on 8.03.409a.
Thanks.
> we're on 8.03.409a.
> Thanks.
Good luck!
> > we're on 8.03.409a.
> > Thanks.
That may or may not work, LoL but it may be worth a shot.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Tue, Apr 3, 2012 at 12:45 PM, cubcrafters_it <
> Good luck!
> evening?
> each night.
> > > we're on 8.03.409a.
> > > Thanks.
Thanks for the help, I appreciate it.
I will have to play with this and adapt to 8.03.
Wish I knew the specifics of the .r, I'd just create a job in SQL Server to do it. Much simpler.
--- On Tue, 4/3/12, cubcrafters_it <jason.navarrete@...> wrote:
Subject: [Vantage] Re: Schedule a Database Conversion
Date: Tuesday, April 3, 2012, 4:45 PM
Â
Good luck!
> > we're on 8.03.409a.
> > Thanks.
You wouldn't want to create a job in SQL server to do it because you would be bypassing the business logic in doing so, which could lead to larger issues.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tony Hughes
Sent: Tuesday, April 03, 2012 1:30 PM
Subject: Re: [Vantage] Re: Schedule a Database Conversion
Good luck!
> > we're on 8.03.409a.
> > Thanks.
If you are in SQL do this,
Go to Test DB when no one else is there,
TUrn on SQL Server Profiler
Run Conversoin
Look at what it does
Replicate!
*Jose C Gomez*
*Software Engineer*
E: jose@...
> wrote:
> From: cubcrafters_it <jason.navarrete@...>
> Good luck!
> evening?
> each night.
> > > we're on 8.03.409a.
> > > Thanks.
When you run a conversion and you are SQL back end all the logic is
probably on a SQL Procedure.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> issues.
> Of Tony Hughes
> Good luck!
> evening?
> each night.
> > > we're on 8.03.409a.
> > > Thanks.
In version 8, I can confirm that SQL doesn't do anything but hold the data.
There's only triggers for the PROGRESS_RECID_ columns. No views. No stored
procs.
But you are right on..... I do a "before" and "after" db backup and see
what changed. Row counts... and create your own SQL script to duplicate it.
Easy.
Sent: Tuesday, April 03, 2012 1:47 PM
*Jose C Gomez*
*Software Engineer*
E: jose@...
> issues.
> Of Tony Hughes
> Good luck!
> evening?
> each night.
> > > we're on 8.03.409a.
> > > Thanks.
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1913 / Virus Database: 2114/4911 - Release Date: 04/02/12
Thank you to everyone for the help.
Anthony Hughes
--- On Tue, 4/3/12, Jose Gomez <jose@...> wrote:
> From: Jose Gomez <jose@...>
> Date: Tuesday, April 3, 2012, 5:47 PM
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
> Â <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> Â <http://www.josecgomez.com/professional-resume/>
> Â <http://www.usdoingstuff.com>
> > issues.
> On Behalf
> > Of Tony Hughes
> Conversion
> job in SQL Server
> file, which I'm
> it's not an
> > Good luck!
> manually.
> maintenance.
> leading to stale
> the cause was.
> > evening?
> > each night.
> > > > we're on 8.03.409a.
> > > > Thanks.
> Note: You must have
> enable access. )
> Report Builder and
> services goto:
> Groups Links
> >Â
> Note:Â You must have already linked your email address
> please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> Groups Links
> Â Â vantage-fullfeatured@yahoogroups.com
Anyone get this to run successfully on a schedule? I used this example but when I run it I get the Progress window to come up with an error "_edit.p" was not found. Unable to run the PROGRESS Procedure Editor _edit.p.
I'm on 9.05.607b and testing this in our pilot environment first. It is a 64-bit box, but I can run the admin tools on it if I use the version in the 32\clientserver directory. My script:
"E:\epicor\oe102a\bin\prowin32.exe"
-db mfgsyssh -H localhost -S 9430
-ininame "E:\epicor\Epicor905\server\config\Epicor905_admin.ini"
-T "W:\epicor\EpicorTestData"
-p "E:\epicor\Epicor905\32\ClientServer\cv\cvxa0041.r"
> Good luck!
> > > we're on 8.03.409a.
> > > Thanks.
