Yes I am referring to the Job Scheduling Board. I thought jobs would show up once created from Order Job Wizard.
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> I would tie a calendar at the resource group level, your calendar should
> reflect the availability of that resource. Make sure that the
> resource/resource group that you want to drive labor and overhead is
> checked as a location. That should be the minimum, there is a lot more
> options beyond that but those will reflect how you want to run your
> operations in further detail. When you say scheduling board, do you
> mean the Job scheduling board?
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
