> Any other suggestions?Sorry, no.
I added the same UD field to the default forms in 9.04.505A and it has and it has remained enabled.
--- In vantage@yahoogroups.com, "itwepicor" <itwepicor@...> wrote:
> I had already tried what you suggested in code - as a matter of fact, I even put a button on the form so that I could run it at will. In the button's code I even included a line to explicitly set the control itself to "enabled." But the control still won't become enabled.
> It's as though Epicor refuses to allow any change, lest the cancellation not accurately reflect the invoice from which it was envoked. I could understand that for crucial fields - but there's got to be a way to modify mere UDF fields of a cancellation.
> Any other suggestions? Am I missing something huge?
> Oh, my version is 9.04.506C.
> --- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@> wrote:
> > Just wondering what version you are running?
> > I added the same UD field to both the invoice and cancellation forms.
> > The UD field I added is enabled by default most of the time.
> > It does become read only depending on my processing steps.
> > If it is not enabled when you need it, maybe you can set the extended properties by calling a sub like this when needed:
> > Private Sub SetExtProps()
> > Dim edvInvcHead As EpiDataView = CType(oTrans.EpiDataViews("InvcHead"), EpiDataView)
> > If edvInvcHead.dataview.Table.Columns.Contains(ShortChar01) Then
> > edv.dataView.Table.Columns("ShortChar01").ExtendedProperties("ReadOnly") = False
> > edv.dataView.Table.Columns("ShortChar01").ExtendedProperties("Enabled") = True
> > End If
> > End Sub
> > --- In vantage@yahoogroups.com, "itwepicor" <itwepicor@> wrote:
> > > How can I enable (i.e. "make editable") controls for UDF fields which Epicor has of its own accord made read-only? I put such a control for InvcHead.ShortChar01 onto the Invoice Entry form. No problem for normal invoices; I can edit and save. But credit memos, which I create using "Create Cancellation Invoice" have teh control for that UDF grayed-out so that I can't edit. How can I cause it to be editable?!
