Use a BPM,
Pre process on the part.Update method.
You can check for the security group and raise an
exception when required
You can control down to the filed that is changed if
required.
Regards,
Stephen
Of Carey S
Sent: 14 October 2008 17:03
Subject: [Vantage] Security Advice
Hello everyone.
I have a small security situation in Vantage 803.404.
We have had many parts that we had to inactivate to make things work
properly and reliably. Detail not important, but I can not count on
anyone to not make the changes that they themselves think should be
implemented.
I created a security group called PARTS MASTER MANAGERS. Only two of us
are members of this group.
First I tried securing menu maintenance, but this does not work because
of the many ways part master could be accessed.
I tried field security, and wanted to lock certain fields, like part
number and description. This does not work because then a restricted
user putting on an order would not have the ability to access or edit
these fields on the part order.
Finally, I turned to process security and simply restricted the update
method from the part bo and this seems to work fine....all except for
one of the people I specifically want to lock out of changing anything
else in the part master "NEEDS" the ability to change the sales prices
on the fly.
Without turning to anything too complex, like service connect, does
anyone have any suggestions as to the best and easiest way to go about
this?
Carey
required.
Regards,
Stephen
Of Carey S
Hello everyone.
implemented.
on the fly.
this?
Carey
