Yes that server has two NICs but one is disabled. I had added a Gigabit NIC to the server and disabled the onboard adapter. Unless it can bind to a disabled NIC I should be OK.
Speaking of ports I run BackupExec on that server and it has remote agents on other servers. I wonder if that could be a port contention issue.
Thanks for the ideas to check,
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Stephen Edginton
Sent: Monday, January 29, 2007 8:43 AM
Subject: RE: [Vantage] Re: [semi-OT] RDP to Vantage Server Question
Do you have multiple network adapters in the vantage server? Sometimes
RDP will bind to the wrong adapter. It Is a registry setting to change
this.
Another thing to check is that nothing else is utilizing TCP port 3389.
Again you can change this port in the registry if required.
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf
Of bw2868bond
Sent: 29 January 2007 14:30
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] Re: [semi-OT] RDP to Vantage Server Question
RDP to Server 2003 is limited to two 'administrative' sessions. If
RDP sessions started and not logged out of properly will cause
issues. Use Terminal Services Manager to check and see if there are
running sessions.
Bernie.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com> ,
"Todd Caughey" <caugheyt@...> wrote:
being able to RDP from the Citrix desktop to the servers. But I can
not do this to our Vantage server and had a support issue Sunday
afternoon. When I try to RDP to it it says that this is not enabled
for this server or it is busy. I've looked all over for a setting
that is different form the other servers but can not find how
to "enable" (or turn off "disable") this facility. I know there are
many people here doing this so any hints where to look first?
-Todd C.
this.
Of bw2868bond
running sessions.
Bernie.
>able to do a lot more weekend support from at home. Really nice is
> Since implementing remote access via a Citrix server I have been
> Thanks,[Non-text portions of this message have been removed]
> Todd Caughey
> Harvey Vogel Mfg. Co.
