Sending the current row in a function call
Hey Guys,
Is there anyway to access a kinetic ui object property and set it to a field in Transview to pass to a function?
I’m trying to fire a function off on a dataset but I want to know which row in that dataset I need to use.
In console via epdebug I can see the ‘viewRow’ property but I am not sure how the kinetic pre-built widgets work when trying to access properties rather than UI data.
At the moment I’m try to set a new field in TransView with {DoneView.viewRow} but that is not working. (Done View is the view in Job Receipt To Inventory).
Patrick
I eventually found a post with the answer
I use #(trans.dataView(‘DonePartTran’).row)# to get my current row number
I fought with this for a bit and discovered an omission in the syntax. I needed to capture the row number for later use so I am storing the value for the row number in a TransView field. Using a row-update workflow item, I specify the EpBinding and in the Value property (JSON Editor) I had to use this syntax. be warned, this syntax -
#(trans.dataView(‘EmpLaborView’).row)#
Should actually look like this -
This message thread editor is removing the underscores.
End
Good to know that posts and replies to these articles remove underscores from any sentence.
If you use the preformatted text function it keeps your underscores.
