Great. I'm glad it worked out.
Randall Weber
IT Manager
TLC Electronics, Inc.
651-287-2972
rweber@...
Of Robert Brown
Sent: Tuesday, September 04, 2007 10:32 AM
Subject: RE: [Vantage] Sendkeys
Thanks very much for the example Randy. I just used a modified version
using VBA/Excel and it worked like a charm.
Randy Weber <rweber@...
<mailto:rweber%40tlcelectronics.com> > wrote:
Below is an example of a simple SendKeys routing written in VBA. Someone
familiar with MS Access and VBA should be able to modify this for your
situation. The SendKeys feature works just like it sounds, it activates
an application then sends keystrokes to that application.
No, it is not a complied application. It is simply a module in MS Access
with a couple sub routines. See below.
Randy Weber
Sample code for Visual Basic Sendkeys
Written for Vantage 6.10.525 Part Maintenance screen using an Access
Database as the source data.
Note: This code will not work as is on your screen because we have
changed the field layout.
Using an Access database with a Part table populated with PN, Desc,
PartType (P or M), ProductGroup and PartClass, I created a form based on
the table and a button which runs the following code. The code activates
the Vantage Part Maintenance screen and types in the necessary data to
enter a part number. Then go to next record in access and so on.
Sub AddPart (PN, Desc, PartType, ProductGroup, PartClass)
AppActivate ("Part File Maintenance)", True
Wait 0.25 'routine to slow down keystrokes or Vantage will error
out
SendKeys "{INSERT}", True 'Add Part
Wait 0.25
SendKeys pn, True
Wait 0.25
Sendkeys "{TAB}",True
SendKeys Desc, True
If parttype="P" then sendkeys"{RIGHT}",true
SendKeys ProductGroup, True
SendKeys PartClass, True
Sendkeys "{F2}", True 'Same as pressing OK button
End Sub
Sub Wait(ms)
'slows down the sendkeys because it is too fast for Vantage
Dim PauseTime, Start, Finish, TotalTime
PauseTime = ms ' Set duration.
Start = Timer ' Set start time.
Do While Timer < Start + PauseTime
DoEvents ' Yield to other processes.
Loop
Finish = Timer ' Set end time.
End Sub
Randall Weber
IT Manager
651-287-2972
rweber@... <mailto:rweber%40tlcelectronics.com>
Behalf
Of Robert Brown
Sent: Friday, August 31, 2007 2:25 PM
Subject: RE: [Vantage] Importing data via Access
Randy,
Do have a VB code example you'd be willing to share to illustrate use of
the SendKeys feature?
...Sounds like a handy little tool.
We imported 10,000 Parts into the part table in v6.x in May of 2003 and
had no trouble. Care must be taken to insure that related tables are
populated first (Part Class, Product Group, etc.).
If you're concerned about possible errors another method is using the
Visual Basic SendKeys feature which literally does the typing for you.
We added thousands of price records this way. I have written numerous
SendKeys functions that we use from time to time inclduing one that adds
part pricing in five columns every day.
Randall Weber
IT Manager
651-287-2972
Behalf
Of Todd Caughey
Sent: Friday, August 31, 2007 7:56 AM
There have been many discussions over the years about writing directly
into the database. Most have come down to this being very risky in terms
of potential to corrupt the database. There are many "trigger" routines
in Vantage that properly populate all related tables and links and
without a very intimate knowledge level of how these work it is very
easy to miss one. I suspect the "tracker" screen is seeing the raw Part
table but can not pull up the complete record due to missing links to
subsidiary tables....things like memos or notes, etc... that would have
needed to have a stub entry (or something, just guessing here) created
at the time the Part was loaded. For all these reasons you can get
yourself into a very bad position, support wise, with Epicor...where
they will wash their hands of an damage you've done to the DB and leave
you on your own. Personally....I stay far away from this sort of thing.
But I am looking forward t o cut/paste grid entry in 8.x because this
runs all the Epicor/Progress routines that assure (we hope) DB
consistency.
The other, "safe" alternative for pre-8 has been to use a scripting tool
to simulate keystrokes and enter via the normal interface. GroundControl
was mentioned often.
-Todd C.
Behalf Of wgoodlive
Sent: Friday, August 31, 2007 7:15 AM
Subject: [Vantage] Importing data via Access
Vantage 5.2. I seem to remember seeing posted before about importing
data by using Access and ODBC. I am trying to import part files into
a "clean" Vantage install using Access. I can fix the part information
in excel and then copy or import into the correct table in Access
(Part, PartWhse, PartPlant). When I go to the Part Master screen in
Vantage the information is there, but I cannot access it. When I click
on a part number nothing happens. Any help please? Is it even
possible to do this?
Bill
Maximum Spindle Utilization, Inc.
The information contained in this E-mail message and any documents which
may be attached are privileged and confidential, and may be protected
from disclosure.
Please be aware that any use, printing, copying, disclosure or
dissemination of this communication may be subject to legal restriction
or sanction. If you think you have received this message in error,
please reply to the sender.
For more information please visit www.harveyvogel.com
Yahoo! oneSearch: Finally, mobile search that gives answers, not web
links.
Need a vacation? Get great deals to amazing places on Yahoo! Travel.
Randall Weber
IT Manager
651-287-2972
rweber@...
Of Robert Brown
Randy Weber
out
Wait 0.25
SendKeys pn, True
Wait 0.25
SendKeys Desc, True
End Sub
Sub Wait(ms)
Loop
End Sub
Randall Weber
IT Manager
651-287-2972
Behalf
Of Robert Brown
Randy,
Randall Weber
IT Manager
651-287-2972
Behalf
Of Todd Caughey
consistency.
-Todd C.
Behalf Of wgoodlive
Bill
from disclosure.
links.
