Vantage 8.03 serial numbering is much more restrictive than previous
versions. Any transaction for a serialized part must include the serial
number. The only way around this is to assign a separate number to the
stocked part that is not serialized then issue the part to the serialized
part number after receipt from subcontract.
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Paul Pachniak
Sent: Monday, November 08, 2010 9:11 AM
To:
Subject: [Vantage] Serial Tracked Parts
We are on 8.03.408B (Progress) and have a situation that I was wondering
if anyone else has a work around for. We have some parts that are set
up as serial tracked as they need serial numbers assigned at the end of
the manufacturing process before they go to stock and are shipped to
customers, the issue is that these parts can have subcontract operations
and when you try to ship them to the subcontractor it wants to know what
serial numbers are being shipped to the subcontractor and the numbers
haven't been assigned yet?
We would appreciate any insight anyone may have in this regard.
Thanks!
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 3114
Fax: 262-252-4974
Email:
paul.pachniak@...
<mailto:paul.pachniak%40aceprecision.com>
<mailto:
paul.pachniak@...
<mailto:paul.pachniak%40aceprecision.com> >
WWW:
http://www.aceprecision.com <
http://www.aceprecision.com>
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION
OF ACE PRECISION MACHINING CORP. If you are an unintended recipient,
immediately (1) delete all copies of this message and any attachments, and
(2) contact the sender. If you are an intended recipient, you are prohibited
from deleting or obstructing this or any other Ace Precision Machining Corp.
proprietary or confidentiality designation that appears on this message or
any attachments. All recipients are prohibited from reproducing, publishing
or disclosing the contents of this message and any attachments to others,
unless you first request and receive written permission from Ace Precision
Machining Corp.
