I have a WorkFlow that I want to act on data in one plant. It makes inventory adjustments and the adjustments are associated with warehouses in the plant. But my workflow fails with an invalid warehouse which seems to imply that I'm not actually acting on the correct plant.
I know that you have to be logged into the plant in order to make adjust transaction on the warehouse.
I have read something along the lines that the Web Services will accept a Company parameter string like CompanyID=MAIN;PlantID=PL2 and not just the simple company name (MAIN). Am I on the right track? Can I just create a Process Variable that looks like my string. above, and map it to the Company node where I would have normally mapped the MAIN value?
