Aha. Since I wrote my original response I have become aware of a potentially better way to do it. The Requester element. Info in online help with heading "Configuring Request/Response Communication".
It works like a message placed into an output channel, except it waits for the response. It gives your workflow the chance to do error detection. Everything else is as described below.
--- In vantage@yahoogroups.com, "thedemondamian" <sheath@...> wrote:
> Alex,
> Would either of these methods work if the file already exists. The file is being placed by a Poster method from another workflow. It could be a few days before the scheduled workflow has to pick it up.
> The file location will never change so putting that in the channel setup is no problem. The file name will be determined by the PO Number of a Sales Order so I wont know which file I need until I am ready to grab the file.
> - Scott
> --- In vantage@yahoogroups.com, "Alex Fiedler" <alex.fiedler@> wrote:
> > Ok there are two ways to achieve what you want to do:
> > Both require you to write the required information (e.g. the file path etc) to an output channel.
> > In the first case the output channel is a FILE output channel. Have a vbs script scheduled to poll for the appearance of this XML file, parse the XML for the path and then copy the specified file into an input channel.
> > In the second case your output channel is a COM output channel and your COM object does the file copy directly. I have not done any output channels which are COM objects, presumably having been written with Visual Studio.
