Here's my new BPM that appears to be working as desired for creating a unique ShipToNum each time:
DEFINE VAR i AS INT.
DEFINE VAR complete AS LOGICAL.
i = 100.
complete = FALSE.
for each ttShipTo where ttShipTo.RowMod = "A":
/*CheckBox01 is a flag set to know the ShipTo is being created from Service Connect*/
if ttShipTo.Company = "STI" and ttShipTo.CheckBox01 = true then do:
do while complete <> TRUE:
find first ShipTo where ShipTo.Company = ttShipTo.Company and ShipTo.CustNum = ttShipTo.CustNum and integer(ShipTo.ShipToNum) = i no-lock no-error.
if not avail ShipTo then do:
ttShipTo.ShipToNum = string(i).
complete = TRUE.
end.
i = i + 1.
end.
end.
end.
i = 100.
complete = FALSE.
complete = TRUE.
end.
i = i + 1.
end.
end.
end.
--- In vantage@yahoogroups.com, "Jeff Rogers" <jeff.rogers@...> wrote:
> Thanks for the responses guys!
> So I think I need a new idea for creating unique shiptonum's through Service Connect. I originally planned on creating the first service connect shiptonum as "100" and then incrementing it from there (finding the last ShipToNum through a BPM and 4GL), but ran into the problem of other people in the company creating additional ShipTos with ShipToNums that are just characters (so I would be unable to conver to integer and increment). Does anyone have an alternate idea of how to create unique ShipToNums when existing ShipToNums may contain characters)?
> Here is the BPM for my original idea:
> /*identify shipto as generated by service connect */
> if ttShipTo.Company = "<insert company name>" and ttShipTo.CheckBox01 = true then do:
> find last ShipTo where ShipTo.Company = ttShipTo.Company and ShipTo.CustNum = ttShipTo.CustNum no-lock no-error.
> if avail ShipTo then do:
> if ShipTo.ShipToNum = "" then do:
> ttShipTo.ShipToNum = "100".
> end.
> else do:
> ttShipTo.ShipToNum = string(integer(ShipTo.ShipToNum) + 1).
> end.
> end.
> end.
> end.
> --- In vantage@yahoogroups.com, "Brian W. Spolarich" <bspolarich@> wrote:
> > See below for the explanation as to why the BPM would fire in multiple
> > companies.
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of Jeff Rogers
> > Sent: Thursday, April 14, 2011 11:52 AM
> > Subject: [Vantage] Re: Service Connect - Creating New ShipTo
> > Finally figured out what was creating the unique ShipTo's in PILOT...
> > there was a BPM running under another company (not sure how it was able
> > to fire for multiple companies). I guess this is the type of stuff that
> > happens when you pickup the development work halfway through the process
> > with little documentation.
> > Of Steven Gotschall
> > Sent: Tuesday, April 28, 2009 9:54 AM
> > Subject: Re: [Vantage] ProPath, Live vs. Test, and BPMs
> > The default Vantage install is such that any BPM method directives apply
> > to ALL Vantage DBs on the server.
> > This means that if you develop a BPM in the TEST database, once enabled
> > it will apply and run in the LIVE and TRAIN databases as well. It will
> > therefore cause problems if you want to test BPMs while developing them,
> > or if you are running several databases, each with different BPM
> > requirements.
> > To enable BPM to apply to one particular DB, you need to set up the
> > Appservers to have unique BPM folders in their PROPATH.
> > The steps below explain how to change the Train DB to use a different
> > BPM folder.
> > 1. In Progress Explorer, right click on the MFGTRAIN803 Appserver.
> > 2. Select Properties
> > 3. Click on Agent ' General
> > 4. The PROPATH should be similar to the following:
> > "E:\epicor\mfgsys803\custom,E:\epicor\mfgsys803\bpm,:\epicor\mfgsys803\S
> > erver\custom,E:\epicor\mfgsys803\Server,E:\epicor\mfgsys803"
> > 5. Change the BPM element of this to a unique path i.e.
> > "E:\epicor\mfgsys803\custom,E:\epicor\mfgsys803\TRAIN\bpm,:\epicor\mfgsy
> > s803\Server\custom,E:\epicor\mfgsys803\Server,E:\epicor\mfgsys803"
> > N.B. It is IMPERATIVE that the path ends in "BPM"
> > 6. Repeat Steps 2 - 5 for the MFGTRAIN803ProcessServer and
> > MFGTRAIN803TaskAgent 7. From Windows Explorer, create the directory
> > specified in this instance "E:\epicor\mfgsys803\TRAIN\bpm"
> > 8. Restart the Appservers. Users will need to be logged off for this.
> > 9. Resave any BPMs created in the Train DB.
> > Background
> > When building a BPM method directive, data is stored in the Vantage DB.
> > When a BPM directive is enabled and saved, the data is processed and a
> > Progress program is generated to disk. The program is generated into the
> > directory specified in the Appserver's PROPATH (folder ending in BPM).
> > When Business Object methods are called via Web Services or a Vantage
> > client, any BPM directives which exist for this method are located first
> > in the propath and are therefore executed prior to base Business Object
> > methods.
