The main workflow is called "SC_Quote/01_Main" with a schema called Quote_v2.xsd.
The sub-workflow is called "SC_Quote/02_NewLine" with a schema called QuoteNewLine_v2.xsd.
--- In vantage@yahoogroups.com, "Blake Clemens" <blake.clemens@...> wrote:
> Ok, what are the names of your schemas in this workflow. ie.. Main;
> Main_EachPart.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> Delmarva Millwork Corporation
> (800) 360-2364 x132
> Of Aaron
> Sent: Monday, June 27, 2011 10:27 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Service Connect - Ending a sub-workflow
> Well, that's what I'm doing. I can detect the "error" condition and jump
> to the end of the sub-workflow. That works great.
> Unfortunately, Service Connect merrily continues on with line 6 next.
> I'd like to be able to abort the entire sub-workflow and all subsequent
> lines.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Blake Clemens" <blake.clemens@> wrote:
> > What if you added a "Choice" to the subworkflow? If you added the line
> > error free then continue as normal but if an error has occurred that
> > jump to the end.
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > (800) 360-2364 x132
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of Aaron
> > Sent: Monday, June 27, 2011 10:17 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Service Connect - Ending a sub-workflow
> > Is it possible to halt the processing of a sub-workflow?
> > For example, I have a workflow that creates a header record. It starts
> a
> > sub-workflow to add 25 lines. Line 5 has some sort of error. Is it
> > possible to have the sub-workflow exit there, return control to the
> main
> > workflow and not continue processing line 6?
> > TIA,
> > Aaron
