Service Connect: Import .NET Ref: Failed to retrieve UD Fields information
Getting SC backup after the upgrade this weekend. When reimporting, I get this error:
Failed to retrieve UD fields information:
Exception of type System.ApplicationException: Failed to load Ice.Core.Session.dll or one of its necessary types
Exception of type System.TypeLoadException: Could not load type ‘Ice.Core.Session+LicenseType’ from assembly ‘Ice.Core.Session, Version=5.0.100.0, Culture=neutral, PublicKeyToken=’.
I’ve reimported a bunch of times, and never got this error. Does anyone have any insight. I need this up before tomorrow…
Ice.Core.Session.dll corrupt?
Well, hopefully this is because the “All Clear” hasn’t been sent yet by Epicor. Fingers crossed that’s it. I will report here once a solution is found.
We used to get this after every upgrade. We decommissioned SC over a year ago now so the details are foggy. Believe you just have to upgrade the kinetic client that is on your service connect server.
Hello and thank you for responding. I upgraded the client install without issue and can login, but for some reason I still get this error. Perhaps I need to reinstall the client? Any help would be appreciated.
Did you log a support case? Usually the process of typing the error message into the subject of a new support case surfaces any relevant KB articles.
Not yet, but we will be doing this. When I pull these DLLs in as our ‘serviceconnect’ user it fails with the error above. When I use a power user account, the DLLs pull in just fine. The ‘serviceconnect’ user has power user rights as well… I don’t understand why one user would work but the other doesn’t?
Impersonation priveliges? Just guessing.
Do you use SSO? We had to create a different Sysconfig that was defaulted to basic to get the UD fields to import.
We do not. Epicor updated us that we need the new version of Service Connect: 12.0.100. Struggling to find where to download the update, but hopefully this is the fix.
Updating the version of Service Connect resolved the issue. Cheers!
