Service Connect - Importing Sales Orders
Sure, I'll email you the workflow in about 30 minutes.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of sbraudrick@...
Sent: Friday, March 18, 2011 12:41 PM
Subject: [Vantage] Re: Service Connect - Importing Sales Orders
I'd love to be able to take a look at it to see the differences if you
could share it with me.
"Blake Clemens" <blake.clemens@...> wrote:
> I have a SC workflow to import Sales Order & Lines. All the line
> information for the part populates... ie. description . I do not have
> the problem you speak of below.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of sbraudrick@...
> Sent: Friday, March 18, 2011 11:39 AM
> Subject: [Vantage] Service Connect - Importing Sales Orders
> I've built a workflow that appears to successfully import Sales Orders
> in to our 9.05.603 installation beautifully.
> The one major problem I'm having is that I cannot click the
"Configure"
> button on configurable items if they are imported in this manner. If
we
> type in the part number in Order Entry it works perfectly.
> What I'd like to do is simulate what happens when you tab out of the
> part number field in order entry and have the system pull all of the
> pertinent information in to the line. A trace tells me this should be
> the SalesOrderService.ChangePartNumMaster service but it doesn't seem
to
> be doing anything.
> Has anyone run across this before?
> Thanks,
> Sean
> Dir. of IT
> HMU, LLC
I've built a workflow that appears to successfully import Sales Orders in to our 9.05.603 installation beautifully.
The one major problem I'm having is that I cannot click the "Configure" button on configurable items if they are imported in this manner. If we type in the part number in Order Entry it works perfectly.
What I'd like to do is simulate what happens when you tab out of the part number field in order entry and have the system pull all of the pertinent information in to the line. A trace tells me this should be the SalesOrderService.ChangePartNumMaster service but it doesn't seem to be doing anything.
Sean
Dir. of IT
HMU, LLC
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of sbraudrick@...
be doing anything.
Sean
Dir. of IT
HMU, LLC
I'd love to be able to take a look at it to see the differences if you could share it with me.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of sbraudrick@...
> be doing anything.
> Thanks,
> Sean
> Dir. of IT
> HMU, LLC
