Service Connect Multi-Plant
I had tried importing the reference with no company or plant defined. Still same result
To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
Sent: Tuesday, April 8, 2014 11:15 AM
Subject: RE: [Vantage] Service Connect Multi-Plant
Did you try and leave the plant info blank when you imported the assembly, then map the plant information from your data in your schema?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of tkoch77@...
Sent: Tuesday, April 08, 2014 7:05 AM
Subject: [Vantage] Service Connect Multi-Plant
Hi All,
I am wondering if anyone has been able to dynamically use .NET references in service connect. I have an input file that is creating a new subassembly, this input file has the company and plant ID's in it. I have tried using the Epicor Logon tab under process properties within the workflow but I still get an error saying cannot update a job from another plant.
Anyone know if this is possible without creating the same workflow for each plant?
Ted
Useful links for the Yahoo!Groups Vantage Board are: ( Note:  You must have already linked your email address to a yahoo id to enable access. )
(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
    Individual Email | Traditional
<*> To change settings online go to:
    http://groups.yahoo.com/group/vantage/join
    (Yahoo! ID required)
<*> To change settings via email:
    vantage-digest@yahoogroups.com
    vantage-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo Groups is subject to:
    https://info.yahoo.com/legal/us/yahoo/utos/terms/
Hi All,
Ted
Rob Bucek
FAX: (715)284-4084
Hi All,
Ted
