We receive an XML output back from equipment on the shopfloor that details the material used and the time taken to produce.
Issue Materials - update the JobMtl table with the correct PartNum if it’s different - then issue the material.
Labor - create a LaborHed record if 1 doesn’t already exist for today - then add a LaborDtl record to record time and quantities.
This is processed at the moment through service connect which I am looking to replace.
I’ve just upgraded to Kinetic 2022.2 over the weekend so I will start reading up on functions and scheduled functions.
Do you know of any decent starting point in terms of user guide?
We just did this with our upgrade. So much easier with function, and widgets provided a lot of the same functionality we found in SC. Add in full visibility through the libraries to add logging to the system monitor and it allows our users to be able to monitor their own processes.
