Hello,
Can any Service Connect gurus out there explain to me why a workflow process would just suddenly stop dead in its tracks with no error message at all?
These same workflows that stop suddenly also run dozens of times to completion throughout the day. So it’s not the workflow. But at least every other day we have a few random processes (from varying workflows) that will stop in the midst of processing records and just sit there with no indication (that I can see) as to why they stopped.
I usually have to track down which record the process stopped on, create a new file with the unprocessed records, and resubmit it to Service Connect. And those remaining records always process just fine. So it’s not as if any of the records are an issue.
I do notice that this usually happens on a file that has quite a large amount of records…but most of the time that same number of records runs to completion without stopping. So why would one workflow process 500 records in one instance but then stop in the middle of processing 500 records in another instance.
I’m not real clear on how Service Connect works as far as does it grab up AppServers on our Epicor Server and let go of them throughout a workflow process or does it grab up one or a set of AppServers and hold onto them till it finishes all the records. And maybe that comes down to our setup. Just thinking that maybe it lets go of an AppServer and then tries to grab another one but they are all busy and so it just gives up.
Just wondering if someone could shed some light on why this is happening and what settings I could look at (Service Connect? Epicor? SQL?) to try to help fix the problem.
We are running Epicor 9.05.702 - 64-bit - Progress
Service Connect 10.1.4020 - on a separate VM
Thank you in advance for any help you can provide,
-Heather
