Service Connect Workflow Quandary
I am working on a new workflow. One that will go to the job and swap
out a part by way of Sales Order. This workflow will be mainly used for
configured parts. For example... if I need to replace the hinges on a
configured door unit. I have this working as long as the Material
Sequence number is provided. My questions to you is... is there a way
for Service Connect to look at each job related to the given Sales Order
and if the part you need changed is present then make the change? For
example... in a configured part there could be many different parts but
I only need one part changed. Can service connect look at each part on
the configured part and determine whether or not it needs to be
changed.. if not then move onto the next part present in the configured
part? The Schema would be OrderNum,Old PartNum,New PartNum. Any help
you could give me would be great!
