I am really stumped as to why this won’t work. It turns the RequestDate read only but not the NeedByDate. Any help is appreciated.
private static void OrderHed_AfterFieldChange(object sender, DataColumnChangeEventArgs args)
// args.Row["FieldName"]
// args.Column, args.ProposedValue, args.Row
// Add Event Handler Code
switch (args.Column.ColumnName)
case "ShipOrderComplete":
if (Convert.ToBoolean(args.ProposedValue) == true)
EpiDataView edvOrderDtl = ((EpiDataView)(Script.oTrans.EpiDataViews["OrderDtl"]));
if (edvOrderDtl.dataView.Table.Columns.Contains("NeedByDate"))
edvOrderDtl.dataView.Table.Columns["NeedByDate"].ExtendedProperties["ReadOnly"] = true;
if (edvOrderDtl.dataView.Table.Columns.Contains("RequestDate"))
edvOrderDtl.dataView.Table.Columns["RequestDate"].ExtendedProperties["ReadOnly"] = true;
if (Convert.ToBoolean(args.ProposedValue) == false)
edvOrderDtl.dataView.Table.Columns["NeedByDate"].ExtendedProperties["ReadOnly"] = false;
edvOrderDtl.dataView.Table.Columns["RequestDate"].ExtendedProperties["ReadOnly"] = false;
break;
