Set label display from a method directive
Bruce,
You could bind the field to a UD Date field. Then, have a post-processing
directive on the GetByID method (you may need GetRows as well), where you
set that date field. You may be able to do that with the canned action
statements, but if you need to go the 4GL route, it would be something like:
For each ttPart:
Assign ttPart.Date01 = today + ttPart.LeadTime.
End.
HTH,
Kevin Simon
SimsTrak Consulting
Butler, Bruce
Sent: Monday, November 28, 2011 4:52 PM
Subject: [Vantage] set label display from a method directive
Is it possible to set a custom label.text field in a form from a BPM?
Example: I would like to set a custom label on the part master table to show
TODAY + PartPlant.LeadTime using a BPM (Stupid customization wizard does not
have a PartPlant Adapter).
Do I simply reference the GUID?
What would be an example of a definition of this?
Thank you,
Bruce Butler
Example: I would like to set a custom label on the part master table to show TODAY + PartPlant.LeadTime using a BPM (Stupid customization wizard does not have a PartPlant Adapter).
Thank you,
Bruce Butler
You could be the Part Label would have to be bound to a dataview
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
> Thank you,
> Bruce Butler
What Version?
What Form?
Can you do a FKV ?
> Thank you,
> Bruce Butler
