Hello guys i would like to set the routing on the print screen as false when the screen load. i already have a code but it is not working could you please let me know what is wrong in my code. Thanks
The code is fine but you will want to do something like this or narrow it down further (sample only). When the report style changes this would catch that change as well.
The code you have to change the routing to false will work but needs to be in another event (EpiViewNotification) to really do what you want. If you add this event and the code it will disable the routing. Basically, by doing within this event you can make sure the report params is not populated again overwriting the desired false routing.
Dan, I tried what you told me placing my code in EpiViewNotification and it didnt work (I clear cache and close epicor and open it back up just in case)
// Custom code for ARInvForm
// Created: 2/25/2018 12:48:23 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinToolbars;
public class Script
// ** Wizard Insert Location - Do Not Remove āBegin/End Wizard Added Module Level Variablesā Comments! **
private EpiDataView edvReportParam;
//this.edvReportParam = ((EpiDataView)(this.oTrans.EpiDataViews["ReportParam"]));
this.edvReportParam.EpiViewNotification += new EpiViewNotification(this.edvReportParam_EpiViewNotification);
this.edvReportParam.EpiViewNotification -= new EpiViewNotification(this.edvReportParam_EpiViewNotification);
//this.edvReportParam = null;
// Begin Custom Code Disposal
// End Custom Code Disposal
//private void ARInvForm_Load(object sender, EventArgs args)
// Add Event Handler Code
//EpiDataView reportparam = (EpiDataView)(oTrans.EpiDataViews["ReportParam"]);
//reportparam.dataView[reportparam.Row]["SSRSEnableRouting"] = false;
//string toolbarNames=string.Empty;
//foreach (UltraToolbar toolbar in baseToolbarsManager.Toolbars)
// if(toolbar.Key == "_utbOutputFormat")
// toolbar.Visible = false;
private void edvReportParam_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
// view.dataView[args.Row]["FieldName"]
// args.Row, args.Column, args.Sender, args.NotifyType
// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
if ((args.NotifyType == EpiTransaction.NotifyType.Initialize))
if ((args.Row > -1))
Test.xml (7.3 KB)
Can you import this customization and try it? From a glance not seeing anything above wrong with the code. This has a message box to show the value for the routing. Are you testing this while in developer mode?
You are opening Invoice tracker - selecting an invoice - and then selecting print, correct? The customization is then in the print dialog screen and that should not be returning true. Assuming there are no other conflicting items such as a BPM this should not happen.
I found something if i set the flag to false and i hide through code the toolbar then the routing stay off but finance needs the tool bar to be visible so the just use the routing whenever they want. I try to change toolbar.visible = false to = true and i got the same problem the routing goes back to be true
Gotcha - the code assumes the default report style is not the routing style, which is not the case for you since the checkbox is being selected right away. Give me a minute and I will send you a way around that.
Try this and remove the other code you had (reportparam.dataView[reportparam.Row][āSSRSEnableRoutingā] = false). Here is example Example.xml (5.0 KB) @Alex let me know if this works for your requirements.
Add ā using Infragistics.Win.UltraWinToolbars;
Then in form load add this.
Sharing our solution to a similiar challange. The afformentioned solution will uncheck the box but will not keep the StateButtonTool unchecked if a user selects a different report style or output.
The attached solution maintains the unchecked state of the StateButtonTool : a user selection is made, the Routing is disabled for the selected report style and/or output.
Iām grateful for the effort above for us being a step further than we would have been. Much appreciated.
