Setting EpiDataView from adapter return-Inspection Processing
Hi all,
I am working on a customization for Inspection Processing that will allow the user to search by a pack slip and return all associated lines from that Purchase Order into the inspection processing PO Receipts area. This process has been designed wherein we will create a misc. receipt of inventory on a Receipt with the pack slip being equal to the first 6 digits of all associated lots of that receipt.
I have not found a good way to search by lot number in the standard Inspection Processing search dialog nor have I been able to see a good solution for a Quick Search implementation for this.
Instead, I have been attempting to set the native EpiDataView in the form to the data returned from the InspProcessing adapter GetReceiptByID method.
This does in fact work, and the data is brought into the form correctly, at least from a visual perspective.
The problem manifests itself in the form behavior after this event fires.
  1. The Clear tool does not clear out any of the data
  2. The lot is not able to be dispositioned, it simply looks correct but the save button will not function.
Is there a trick to correcting binding new data to a native dataview?
Sorry to bump, but any help or insight would be much appreciated!
Hi Aaron,
Why can’t you use a quick search? I’m not too familiar with Inspection Processing
ok so I did some poking around,
Get a hold of the existing adapter instead of instantiating your own like this (warning winging it without an editor so syntax may not be perfect)
var myInspAdapter = ((InspProcessingAdapter)(this.csm.TransAdaptersHT["oTrans_inspAdapter"]));
myInspAdapter.GetReceiptByID(....) etc...
oTrans.NotifyAll();
This is great, thanks for coming through, as always! :slight_smile:
I am curious, I’ve never seen this technique to access a native adapter. I’ll have to use this more often, thank you!
