I'm looking at some reports that are failing the conversion from E905.700C to E10.1.400.14.
In the report data, we are pulling in date fields, and comparing values using a Shared DateVar. I should issue a disclaimer right here and say I didn't write these reports, I inherited them. I'm not that fancy with Crystal. At any rate, when I try to run the report, it fails with the message (for example): "Error in formula ShipDate: 'If Shared Datevar ShipDate=Date(00,0,0) then Shared Datevar ShipDate:={BAQReportResult.ShipHead.ShipDate}' A date is required here."
So, I go into Crystal and select Set Datasource Location, fill in the location for the xml, and Map Fields opens. My ShipHead.ShipDate field is unmapped, and won't let me map it. So, what I'm wondering is
1) Can anyone help me?
2) Is any of this due to the newly changed display formats of years to two digits?
3) Why haven't I won the lottery yet?
Thanks for any help you can provide, and thanks for reading this book.
Sue
