Trying to switch file attachments to sharepoint. We use 0365. I was able to figure out the directory ID and application ID but I cannot seem to figure out where I get the Sharepoint Certificate Thumbprint.
Can someone point me in the direction on where I can get it?
I read the application help and didn’t see anything in there.
For some reason this documentation is still not in online help (it is somewhere in pdf on EpicCare).
You need to create or take an existing certificate and add it into AAD application you created and into Digital Certificate Store UI in Kinetic. Thumbprint from it will be in the combo for SharePoint online.
The simplest way is to use Digital Certificate Store menu action to generate self-sign certificate. It will save .cer file locally for you, then you import this cer file in AAD.
Unless something changed, it was a folder per company. Underneath that one will be a folder for each object (OrderHed, JobHead, etc.), which is where the documents are stored.
