Calvin,
Did you make sure that both the companies have the check box in the report style(s) to make it available to them? Also, did you make sure the report style(s) use the customized RDD (not the system RDD)? Are you doing this for a BAQ report or another RDD report?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of c.krusen1
Sent: Wednesday, May 15, 2013 10:57 AM
Subject: [Vantage] Sharing Crystal Reports between Companies (Ver 8.03.409C)
We've recent added another company (new company in same database) but are having problems with Reports in the new company.
I've gone into Report Style and made the desired reports available for the new company, and they show up on the list of Styles.
But when I preview the report using our customized style, the data fields are all blank. The data shows up fine when using cutomized style on the original company(MC).
Just to be clear, the standard style works for both companies(MC and CN), but customized style (using the same data definition, but different .rpt file) only works in the original company(MC).
I've opened the .rpt file in CR Designer, but can't find anything that would restrict display data because of the company field.
Any ideas where to look would be appreciated.
Thanks in advance
Calvin
Thanks in advance
Calvin
