Just in case anyone has a base rpt that can get me started, per shift this is some of the info we are looking for
Setup Efficiency % :: (Sched Op time / Actual Labor) OpCode S
Run Efficiency % :: (Sched Op time / Actual Labor ) OpCode P
Net Effective LBs / Hr :: ((Total issued LBs paper - Total Pieces Produced (Net Wt.)) / Shift Hours)
Net Effective Bags / Hr :: (Total Pieces Produced / Shift Hours)
Good Quantity :: (Total Pieces Produced)
Scrap Quantity :: (Total issues LBs Paper - Net Effective LBs)
Crewed Time :: (Total Direct Labor) OpCode P
Non-Crewed DownTime :: (Total InDirect Labor) OpCode S
Actual Setup :: (Total Actual InDirect Labor) No-Downtime Code OpCode S
Standard Setup :: (Total Est InDirect Labor)
Actual Run :: (Total Actual Direct Labor)
Standard Run :: (Total Est Direct Labor)
Otherwise if someone has recommendation on which tables I will all need...? I find the same kind of data in several different tables, but I end up with duplicate record type issues in a BAQ report. Not sure where to start.
--- In vantage@yahoogroups.com, "jgiese1988" <jgiese@...> wrote:
> Does anyone have a shift report that offers similar information to the attached https://www.dropbox.com/s/mvolufn7x9tmq78/Copy%20of%201031%20Extrusion%20HB%20Shift%20Efficiency%20Report%20Version_8.xls that they would be willing to share? This is for my own company using metrics examples from another company (the attached), not for consulting.
