Show Kit Details
Thank you for the info Debbie,
I was not aware of the workaround recommendation, or that it would
make a difference "pulling" from the Order vs. "pushing" from the
Quote. I was under the impression the results would be the same. We
will be testing this today.
We are also having the problem with materials not showing up in the
Jobs which is a result of their not coming across from Quote to Order.
I'm guessing that not many users create Orders using the Order Wizard
from the Quote or there would be more complaints to get this fixed.
Thanks again for your assistance.
Dave
8.03.406A Progress
Xybix
--- In vantage@yahoogroups.com, "Debbie Stokes" <debbie.stokes@...> wrote:
> Hi Dave,
> I guess the show kit details box may not be stored in the db. It may be
> a screen setting. In which case your best chance of changing it is to
> use a customization. However customizations do have their own overhead
> so it may depend on whether you already use them as to whether it is
> worth setting one up for this.
> Disappointing to hear that is still an issue in 406a. We are on 305L and
> have seen it, and several permutations of it (the other problem being
> kits that don't always pull their components across from quote to
> order). Be aware we have also seen the situation where the kit parts are
> visible in the summary view but are not attached to the parent when
> viewed in the tree structure. Epicor inform us this is fixed in 40x.
> These were their suggested workarounds until we move to 400.
> 1. Whenever a user adds a line to a quote or to a sales order make
> sure they press save before the next line is added. Also make sure they
> press save before a new quote/order is created. If they do this all
> components will pull through to the quote/order correctly.
> 2. Rather than converting a quote to a sales order in the Quote Entry
> screen go to the Sales Order Entry screen instead and create a new sales
> order. Then go to Actions -> Get Opportunity/Quote. If this is done all
> components will pull through to the order correctly.
> Does anybody know which table the "Show Kit Details" checkbox is on?
> We would like to have it default to checked instead of not checked.
> There is the persistent problem of Kit details with no ShipDate when
> created from a Quote using the Create Order Wizard. I looked into
> customizing the form and could not find anywhere to set the default
> for the field to TRUE.
> Thanks,
> Dave
> 8.03.406A Progress
> Xybix
> kind regards
> Debbie Stokes
Dave
8.03.406A Progress
Xybix
Hi Dave,
Dave
8.03.406A Progress
Xybix
kind regards
Debbie Stokes
