Signature Methodology, Test Cases Documents
Hi, Since I am rolling out new green field implementation for Epicor 10.2.200.x .
I happened to see Signature Methodology in Epicweb. The version is stated as V5 in Zip folder type. But documents version are so old dated 2005. Wondering if any updated version available so I can use it?. Is it mandatory to follow Ditto Signature Methodology? As better approach like PMBOK is in place. Kindly suggest me the best practices.
Thank you.
You can take the Signature Methodology Class in Epicor University
Thanks Jose. There isn’t any only on demand webinar in place since I am in India and checked online option nothing available.
Thanks again Jose. I saw that and did it initially. Then later found out the documents in Epicweb which is very old version.
