The one problem with this report is that it doesn't show the revision of the material parts. Unfortunately, I haven't been able to find a way around this except through the adapters, where you can use the BomSearch function to return the entire bom and all of its levels and once you do this you have access to the material part revision.
> Travis, one last question, can I just import the BAQ? never done before. Should I change the company and other fields prior to the import? Thanks.
> Ken
> From: "Late, Travis" <tlate@...>
> To: vantage@yahoogroups.com
> Sent: Fri, April 9, 2010 9:26:34 AM
> Subject: RE: [Vantage] Re: single level BOM
> Here is the link:
> http://tech. groups.yahoo. com/group/ vantage/files/ Dashboards/
> Single Level BOM with cost.
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Ken Taylor
> Sent: Friday, April 09, 2010 11:18 AM
> To: vantage@yahoogroups .com
> Subject: Re: [Vantage] Re: single level BOM
> Travis, that will be great. What is the name of upload? Thanks a million.
> Ken
> ____________ _________ _________ __
> From: "Late, Travis" <tlate@m-bco. com <mailto:tlate% 40m-bco.com> >
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> Sent: Fri, April 9, 2010 9:00:29 AM
> I have a BAQ and crystal report for single level BOM that I can upload
> to the yahoo group.
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
> Of saab_barracuda
> Sent: Friday, April 09, 2010 8:16 AM
> Subject: [Vantage] Re: single level BOM
> You can't change the system RDD but you can copy them and make changes
> to the copy.
> --- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> , Ken
> Taylor <ktaylorv@.. .> wrote:
> > Does anyone out there has a bill of material crystal from a BAQ? They
> tell me I can't modify any of the Data definitions from Epicor. Do I
> have to base it on a subreport? any info you may have will be
> appreciated. Thanks.
> > Ken
> M-B Companies Confidentiality Notice:
> This message is being sent by M-B Companies. It is intended exclusively for
> the individuals and entities to which it is addressed. This communication,
> including any attachments, may contain information that is proprietary,
> privileged and confidential if you are not the named addressee; you are not
> authorized to read,print,retain copy or disseminate this message or any part
> of it.If you have received this message in error, please notify the sender
> immediately by email.
