I have reported this issue to Epicor several times over the last years but it seems worse in 2026.100 to the point where I could not get the new app wizard to launch at all. Here is the answer courtesy of AI, and the workaround works (verified in chrome, 2026.100, public cloud, have not tried other versions).
Application Studio “Wizard: Create Application” Silently Missing
Startup race condition prevents the Application Wizard from registering, so the “Create new App” selector never appears
Summary
Clicking New App in Application Studio is supposed to open the “Create new App” selector offering two options: Manual and Wizard: Create Application. In affected sessions the selector never appears — clicking New App jumps directly to the manual “Add New” panel, and the Application Wizard is simply gone. Nothing is written to any server trace or log, because the entire failure happens client-side during shell startup.
The cause is a race condition between two parts of shell boot: the wizard’s registration code subscribes to a locale event that may have already fired, on an event bus that does not replay missed events. Any session that loses that race gets no Application Wizard, silently.
Steps to Reproduce
The outcome is timing-dependent, so it does not reproduce on demand in every environment — but on our third environment it reproduces in effectively every session:
- Sign in to the Kinetic browser client.
- Open Application Studio.
- On the Applications tab, click New App.
- Actual result: the manual “Add New” slide panel (Type / Prefix / Id) opens immediately. Expected result: the “Create new App” selector listing Manual and Wizard: Create Application.
Hard-reloading the browser tab (Ctrl+Shift+R) does not change the outcome in our environment. Environments with slower locale-resource loading or faster REST bootstrap show the selector normally — which is why the feature appears to “work in one environment but not another.”
Root Cause Analysis
All findings below come from reading the production client bundle (main.cd7023397770b273.js) served by the 2026.1 environment; the same logic is present in the 2025.2 bundle.
- The selector only appears when more than one wizard is registered. EpWizardManagerService.openWizardSelector collects the wizards registered for entity StudioApplication. If the total is exactly one (the built-in Manual item), it resolves that single option immediately and no selector is shown. A missing wizard registration therefore produces no error — just the “straight to Add New” behavior.
- The ERP wizard registers only in response to an event. The ERP-side registration service (the class using the ErpRegisterWizard string table) registers the guided-setup wizards (grid / panel card / data view) immediately in its initialize(), but registers app-create-wizard (“Wizard: Create Application”, component erp-create-app-wiz) only inside a subscription to the EP_EVENT_LOCALE_LOADED event — presumably so its display strings re-translate on locale changes. There is no initial registration outside that subscription.
- That subscription is created late. KineticErpService.onInitialize() waits for epPlatformService.onConfigured() (REST-dependent), then runs a long chain of service initializations; erpCreateAppWizService.initialize() is near the end of that chain.
- The event bus does not replay. EpEventService uses a plain RxJS Subject (this._eventBus = new Subject()); its on() method is just a filter over the stream. A subscriber that arrives after an event was broadcast never sees it.
- The locale event can fire first. The locale service broadcasts EP_EVENT_LOCALE_LOADED as soon as language resources finish loading and merging. When those resources come from cache (and/or the REST side of bootstrap is slow — for example an idle sandbox application server), the broadcast happens before step 3 creates the subscription. The registration callback then never runs for the lifetime of the session.
Supporting detail: the guided-setup wizards — registered unconditionally in the same initialize() — are present and functional in affected sessions. This proves the initialization chain ran to completion and isolates the failure to the event subscription specifically.
Suggested Fix (For Epicor Development)
Any one of the following would eliminate the race:
• Register app-create-wizard immediately in initialize() (as the guided-setup wizards already do), keeping the EP_EVENT_LOCALE_LOADED subscription only to re-register with refreshed translations; or
• Give EP_EVENT_LOCALE_LOADED replay-to-late-subscriber semantics (ReplaySubject(1) behavior for this event); or
• Have openWizardSelector query wizard providers at click time instead of depending on boot-time, event-driven registration.
Workaround
A DevTools console snippet that re-broadcasts EP_EVENT_LOCALE_LOADED on the Application Studio tab, after which the selector and wizard work normally for that session.
- Press F12
- Paste code snippet below into the console and press enter
- Go back to the App studio page, switch from one tab to another and back again
- Try to launch the app wizard again
let req;
window.webpackChunkhomepage.push([["__epi_fix__"], {}, r => { req = r; }]);
if (!req || !req.m) return console.error("webpack require not found");
for (const id of Object.keys(req.m)) {
let exp; try { exp = req(id); } catch (e) { continue; }
if (!exp || (typeof exp !== "object" && typeof exp !== "function")) continue;
for (const k in exp) {
let C; try { C = exp[k]; } catch (e) { continue; }
if (!C || !C.prototype) continue;
const P = C.prototype;
if (typeof P.broadcast === "function" && typeof P.on === "function" && typeof P.getDefaultModel === "function") {
let nm = ""; try { nm = ((P.getDefaultModel.call({}) || {}).objectName) || ""; } catch (e) {}
if (nm === "EpEventService") {
const orig = P.broadcast;
P.broadcast = function () {
if (!window.__epBus) {
window.__epBus = this;
setTimeout(() => { this.broadcast("EP_EVENT_LOCALE_LOADED"); console.log("%cCreate-App wizard registered — New App will now show the selector", "color:green"); }, 0);
return orig.apply(this, arguments);
return console.log("bus tapped — click anywhere once");
console.error("EpEventService not found");
