I am using Solution Workbench to create a solution. I have a dashboard in which I have added a New Custom Sheet and an AppBuilder Panel. To do this I clicked on the AppControlMenu ID. I am trying to figure out how to move this to another environment. Where or how do I add these to the new environment?
I found this. You move the dashboard that you used to create the Menu Item. You add it to the Solution Workbench along with the menu item.
