Solution Workbench Import/Export
In Pilot instance we have a few solutions which are basically bundles of BAQs that build and install into Production just fine. However, after a refresh of Pilot from Production the Solutions are all gone.
How do we import/export solutions next time so they persist in solution Workbench after a refresh?
I don’t think they will. When you copy Live down to Pilot, you’ll get whatever Live had. The best you can do is export them from Pilot to a saved location and re-import after the refresh.
Thanks for your reply.
How do you export/import a Solution in Kinetic so that the solution design is in Solution Workbench?
I understand Build/Install but cannot find Import/Export?
I could DMT BAQ export Solution and SolutionDtl, but I don’t see a DMT option to import those.
TIA,
Josh
Epicor is still trying to determine if people want that feature or not. You can vote here.
https://epicor.ideas.aha.io/ideas/ERP-I-219
I was afraid of that. How are folks handling this? Do you have a 3rd DEV environment and never refresh? Or do you recreate solutions all the time?
Seems a blocker may be guid conflicts between environments but you’d think they could just create the solution design data upon install from .cab using the new guids (for unsealed solutions)
Or…
Make the software more friendly for DevOps | ERP-I-139
Lots of complaining, generally.
I can’t see where you would need this. If you built the solution from pilot and installed in production all of the solutions work is in production now.
If I am actively working on something and want to refresh my dev environment I either make a solution or export what I am working on and then reimport.
I suppose need is debatable but remaking the same solutions in solution workbench after a refresh being a tedious waste of time that introduces risk is not debatable.
At least the ability to DMT Solution/SolutionDtl is wanting.
I have always disliked the lack of ability to see an imported solution in the destination system as a true solution.
Unless that has changes recently, and I am too stuck in my ways to check! :thinking:
I’m with @Mark_Wonsil on the improvement required and perhaps we are on the cusp of things with the ice. Common db thingy.
FWIW, doing this after a refesh works pretty well. I think Mr Shoemaker suggested something similar on here somewhere.
Solution Workbench
1- Create New Solution - named like the one you’re importing
2- Set that as Tracked Solution
3- Install Solution file
4- Open New Solution, Tracked page, click Move to Solution
5- Turn off solution tracking or set it to another.
Your New Solution now has the items imported.
Idea: This should be a checkbox on the Solution Import slider.
This is broken (2025.2.7). MetaUI Items don’t reliably move from tracked to solution
