Is anyone able to get changes to CustomLayers to show up in Tracked view with Solution Tracking turned on? I never get any changed XXXDef item type in Tracked view. Thought this was working a few months back.
Not tested as personally I’ve never used the tracking in real life as I prefer to track manually.
However, I wonder if this is a bug in 2025.2. As solution workbench changed how it handled layers. It used to move the raw xxxdef record. Now it uses MetaFX to move it, the same as export / import in application studio.
Thanks Ben. That sounds about right timing wise.
Also about the same time the tracked solution began taking 8+ minutes to load. ![]()
