Solutions Manager
Thank you both for confirming it's not me. That is always nice to know. I'm glad they could offer such a valuable tool with a worthless implementation. Hooray :)
In specific I was not aware I could not export or move print rules. Let the nightmare commence.
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> Hi,
> I used Solution manager with some success in 9.04.506.
> Mostly for form customizations.
> I did not use it for BPMs, RDDs or report styles.
> All had issues with SM in 9.04.506.
> BPMs already had pretty good export/import.
> RDDs were the biggest problem (with autoprint rules).
> My co-worker found the tables and was able to copy the records with queries.
> Not for the faint of heart, but in our case it worked well and saved a lot of time.
> We went to this extreme since RDDs were taking a LOT of time to copy manually - and in several cases we had entry errors, especially with the autoprint rules. (For some reason, rules weren't visible after they have been saved, I had to use a BAQ to see them).
> --- In vantage@yahoogroups.com, "jgiese1988" <jgiese@> wrote:
> > Running Epicor 9.05.604A. We have had consultants come in and make BAQs, customizations, reports styles, etc. as well as I have created some of these items too. The problem is they are all in a test environment and not the Production environment. The last consultant we had, turned me on to the Solutions Manager, but made clear that he could not get it to work. I as well cannot get it to work. I just get a numerous amount of errors during the Solution Install. It seems pretty straight forward in the building of a solution. Pick the parts you need and it packs them away. Has anyone gotten this to work before?
I used solution manager to move everything from test to live, in
9.05.603. There were a number of annoying bugs but I worked past them.
When saving a solution (prior to a build) it lost the list of
customizations, and they needed to be re-selected each time.
Numerous error messages about conflict/overwrite importing a solution,
didn't seem to matter what I answered - some imported, some didn't.
Custom report styles didn't get imported when part of a larger solution,
but I created a second solution with just those styles, and that worked
A customization on a subform didn't get imported - possibly my error
when re-selecting due to the first problem, or possibly a separate
issue. Created yet another solution with only it & worked.
Reports created with the financial report designer can't be included in
a solution, need to re-create manually.
I didn't bother to submit help calls for most of these :-(
Brian.
Of jgiese1988
Sent: Tuesday, August 09, 2011 8:46 AM
Subject: [Vantage] Solutions Manager
