This is probably a simple fix but I created a solution on Pilot from a set of BAQ’s, I then imported the solution into Third but I cannot see it in the Solutions Workbench front screen.
However if I go into “Installed Solutions” it is there and also if I look in Application Studio all the BAQ’s are now there.
From this I was wondering if it was just because I did not tick the “tracked” on the solution so I created the solution again and imported, selecting Delete Previous Install, I then logged out and back in but still it does not appear on the front screen.
Any ideas?
Should I have first created a solution matching the name on Third before importing the file?
OK to add to this I have now tried making the original solution tracked, built it, created a solution on Third matching the one on Pilot, Installed the file, deleting the previous but there are no items appearing in the solution.
This is a known issue. Installed solutions don’t show in the solutions list tracked or not. You can only see them in them in the Installed Solutions overflow menu item, where you can delete them.
Rule of thumb if you create the solution in an environment and that environment is copied from one application server instance to another (i.e Live to Third) then you will see the created solution in the panel card when you load solution managment.
