I have created a dashboard & added a button ‘Adjust Quantity’. This button needs to open up the Quantity Adjustment Menu. I’ve added the Custom Control & Control Event for this button but I’m having issue with the Code.
Ok well, I figured out what I was doing wrong. I had to create the dashboard without customizing the tracker view. Add it as a dashboard assembly. Then open the dashboard in the menu where I placed it. Then apply the customization
Thank you so much for putting the solution here. I was trying to do a dashboard refresh and was running into the ‘The name ‘oTrans’ does not exist in the current context’ error.
