Space character problem in bar code
George,
I think it was probably your trim/replace suggestion that worked, not my don't do that suggestion. That is interesting the commas in barcodes get interpreted as spaces in Vantage. When I get some time, I'll have to test that with our setup in case it comes up again. I thought there should be a way to do it but could never get it to work out. Thanks for the tip.
Cheers,
Chris Clunn
--- In vantage@yahoogroups.com, "pcivantage" <vantagegroup@...> wrote:
> Chris;
> Glad your fix helped Todd with this.
> Vantage still recognizes data with spaces and # signs for several key fields in bins etc. Vantage also allows you to paste characters into a Memo field that are control or formatting codes that mess up your DB. Vantage also allows you to put more than 1,000 characters in a memo field that is limited to that many. There are a lot of places that data can be entered incorrectly into our database, and putting stops in place is a full time task.
> We have 32,000 parts where they often used these types of characters. A barcode with a big gap in it will not scan, so the code replaces that with the comma character that IS encoded in the bar, and translates back to a space from the scanner, so all works fine. We cannot change a part number they have been using for years, but can automate the data entry part. Productivity is the goal, and often the data is less than perfect.
> Thanks for the suggestion and the joke reference. ;)
> Regards,
> George Hicks
> --- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@> wrote:
> > George,
> > How would this help? This might work to get the barcode to read but certainly doesn't help Vantage translate the data.
> > Todd,
> > This reminds me of the old joke...
> > Man goes into the doctor and says, "Doctor, it hurts when I do this."
> > Doctor says, "Then don't do that."
> > Problem solved.
> > Seriously, barcodes should be used on key fields. I'd have to ask why you have spaces in your key fields? Don't do that. ;) This may be out of your control (customer requirements, other departments, legacy systems, etc), so if you must have spaces check with your barcode scanner manual. There may be a setting to read special characters. Then you can replace the space with the special character in the Crystal Report formula (or whatever you are using to generate barcodes.
> > I had to go through some trial and error with our setup to get the scanners to work with the tab key so that we could have a single barcode for job <tab> assembly <tab> operation to speed up clock-in activity. I posted my barcode setup list for Symbol scanners on the group a while back but I really don't much about it other than the list works for me. My list didn't work for spaces though. One time, Prod Control tried to create a job number with a space and I had to tell them, "Don't do that." Problem solved.
> > Good luck,
> > Chris Clunn
> > --- In vantage@yahoogroups.com, "pcivantage" <vantagegroup@> wrote:
> > > Todd;
> > > Create a formula to remove the space and add a comma. This will remove the space from the barcode, but will allow the gun to function correctly. Make sure your gun is set to allow Code39 Enhanced codes.
> > > This example uses the Part Bin table, but you can use whatever table and field you need.
> > > Formula called "RemoveBarSpaces":
> > > TRIM(REPLACE({PartBin.BinNum}," ", ","))
> > > Then also remove any `#' signs which mess up your codes as well, like this:
> > > Formula Called "RemoveSpaceAndPound":
> > > TRIM(REPLACE({@RemoveBarSpaces},"#", "/C"))
> > > I hope this helps you out!
> > > George Hicks
> > > PCI
> > > --- In vantage@yahoogroups.com, tgilbert@ wrote:
> > > > We have run into a problem in scanning DataWorks Bar 39 bar codes that contain space characters (strings without spaces scan fine). I read that using = or ~ characters can be used in some bar codes to designate a space character but that doesn't work either.
> > > > Has anyone run into this?
> > > > Thanks,
> > > > Todd Gilbert
> > > > GCM, Inc.
> > > > Vantage 6.1
Todd Gilbert
GCM, Inc.
Vantage 6.1
Todd;
George Hicks
PCI
> Thanks,
> Todd Gilbert
> GCM, Inc.
> Vantage 6.1
George,
Todd,
Problem solved.
Good luck,
Chris Clunn
> Todd;
> George Hicks
> PCI
> > Thanks,
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
Chris,
I completely agree with you and have already had that conversation with
those who thought it was appropriate to do it that way. However, I'm
stuck trying to make their current configuration work.
The TRIM and REPLACE syntax from Chris works like a charm!
Todd G.
Of saab_barracuda
Sent: Tuesday, March 01, 2011 6:11 AM
Subject: [Vantage] Re: Space character problem in bar code
George,
Todd,
Problem solved.
Good luck,
Chris Clunn
> Todd;
and field you need.
this:
> George Hicks
> PCI
> > Thanks,
> > Todd Gilbert
> > GCM, Inc.
> > Vantage 6.1
Chris;
Regards,
George Hicks
--- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@...> wrote:
> George,
> Todd,
> Problem solved.
> Good luck,
> Chris Clunn
> > Todd;
> > George Hicks
> > PCI
> > > Thanks,
> > > Todd Gilbert
> > > GCM, Inc.
> > > Vantage 6.1
