You would be better off using a UD Adapter and creating a base BPM to
pass back your specific requirements along with performing all logic
server side.
Or create your own BO and adapter if you have the SDK,
or if the Resource adapter is closer use that as a basis for the dataset
and create a base BPM on that instead under certain CallContext
conditions.
Regards,
Stephen
Of drew.pete
Sent: 01 September 2010 16:27
Subject: [Vantage] Speeding up data retrieve on customization
Recently, I created a customization that retrieves a good amount of data
using a few different adapters. The problem is, it takes quite a while
to get that data, do the calculations, and then populate the ultragrid.
I'm working on exploring new faster ways of getting the data I need.
Based on the following pseudocode, do you have any suggestions?
Sub On change in date() 'of form object
Declare new dataset ds
CreateDS(ds)
Assign ds dataset as datasource to ultragrid
End Sub
Sub CreateDS(ByRef ds)
Declare table
Add columns to table
Add table to ds dataset
Declare Resource Adapter
BO Connect to Resource Adapter
Get data using whereclause(usually returns aboutn 100 to 200 rows)
Loop through each Resource Record
CalcHours()
Populate rows in dataset ds
End Loop
End Sub
Sub CalcHours()
Declare LaborDtlSearch Adapter
BO Connect to LaborDtlSearch Adapter
Filter data using whereclause (usually get about 15 to 20 records)
Loop through each LaborDtlSearch Record
GetJobStds()
Running total calculated using returned JobStds
End Loop
End Sub
Sub GetJobStds()
Declare JobOperSearch Adapter
BO Connect to JobOperSearch Adapter
Filter Data using whereclause (usually returns 1 record)
Set values of variables passed into sub
End Sub
Thank you in advance,
Drew
server side.
conditions.
Regards,
Stephen
Of drew.pete
CreateDS(ds)
End Sub
Declare table
CalcHours()
End Loop
End Sub
Sub CalcHours()
GetJobStds()
End Loop
End Sub
Sub GetJobStds()
End Sub
Drew
