Spinning Wheel of Death in Kinetic
When we right click on a part from part tracker to part transaction history then to time phase we will get a spinning wheel of death of the data trying to be returned and it will not return data. Only work around I have been able to get it to work is by opening the application directly and it works. Also, I have seen clicking the browser refresh a few times will get data to return. Is there anything anyone can suggest to help fix this issue.
We are on version 2023.2.17
Hi @Devin.Draeger,
We are also experiencing this issue after updating to patch .17 and have raised a support case with Epicor. Will keep you posted.
We do have a case open as well case number CS0004361282
I have noticed this problem since we upgraded to 2023.2 in Feb.
We’re on 2023.2.19 now and haven’t noticed it happen yet. But I don’t use it every day
I had some complaints about this very issue this morning. We’re on 2023.2.15. Wondering if I should install a later version of 2023 or just move forward with 2024?
Most of the spinning wheels of death have been fixed in 2024.1 from what i can see.
