Splitting text column by ~ tilde?
I’m having a write a SORel change log report and data from the OrderRel table. The field ChgLog.Key2 contains the SONum, Line, and Rel data I need but in a tilde delimited manner.
I’ve been working to split it out and got the SO number to work via the case below, but I can’t get Line or Release to work.
Case
When ChgLog.Key2 like ‘%~%’
Then LEFT(ChgLog.Key2, PATINDEX(‘%~%’, ChgLog.Key2) -1)
End
For LINE, I thought I was onto something by modifying the Case above with Substring but I can’t get the syntax correct.
For REL, I was trying RIGHT instead of Left in the syntax but it returns too much data, ie: 162~1~21 instead of just 21 for the Rel number.
case
Then Right(ChgLog.Key2, PATINDEX(‘%~%’, ChgLog.Key2) )
End
Are you in the BPM expression editor?
If I recall, it was something like: splitLine = Ice.entry(1, ChgLog.Key2, ‘~’)
Here is a bit of code I used from something similar. First set it to an array and then to a variable.
I am assuming BPM editor as well.
string [] PartKeys = partTranPKs.Split('~');
int intTran;
int intSysTime;
int.TryParse(PartKeys[2], out intTran);
int.TryParse(PartKeys[1], out intSysTime);
using (var txScope = IceContext.CreateDefaultTransactionScope())
	var PTRow = (from PT in Db.PartTran where
				PT.TranNum == intTran &&
				PT.SysTime == intSysTime select PT).FirstOrDefault();
	if(PTRow != null)
		PTRow.EWO_c = callContextBpmData.Character01;
	Db.Validate();
	txScope.Complete();
I’m writing a BAQ so all I can do is a calculated field in SQL commands.
The field ChgLog.Key2 lists the SP, Line, Rel separated by ~'s: 12345~1~1. I need to split the three apart into calculated fields, so I can use them to relate to the OrderRel table.
This is a calculated field I use in one of my BAQs to split OrderHed.SalesRepList which is a list of 5 rep IDs separated by ~.
Eg: 100~240~900~923~235
It’s searching for which rep has the split of 100% and getting the value from the tilde string with this statement: [Ice].entry(1,OrderHed.SalesRepList,’~’)
case
    when OrderHed.RepSplit1 = 100 then [Ice].entry(1,OrderHed.SalesRepList,'~')
    when OrderHed.RepSplit2 = 100 then [Ice].entry(2,OrderHed.SalesRepList,'~')
    when OrderHed.RepSplit3 = 100 then [Ice].entry(3,OrderHed.SalesRepList,'~')
    when OrderHed.RepSplit4 = 100 then [Ice].entry(4,OrderHed.SalesRepList,'~')
    when OrderHed.RepSplit5 = 100 then [Ice].entry(5,OrderHed.SalesRepList,'~')
end
Your example would be something like this:
For the SP: [Ice].entry(1,ChgLog.Key2,’~’)
For the Line: [Ice].entry(2,ChgLog.Key2,’~’)
For the Rel: [Ice].entry(3,ChgLog.Key2,’~’)
The 1-3 being the index of the array that the split creates.
Edit** I have used that case statement to join the SalesRep table as well, so you should be able to use it to relate to the OrderRel table.
Check this out. It breaks out a tilde-delimited field into multiple
calculated fields in a BAQ.
1st Calculated field
(case when [Ice].num_entries(QuoteDtl.ConfigData_c, ‘~’ ) > 0 then
[Ice].entry(1, QuoteDtl.ConfigData_c, ‘~’) else ‘’ end)
2nd Calculated field
(case when [Ice].num_entries(QuoteDtl.ConfigData_c, ‘~’ ) > 1 then
[Ice].entry(2, QuoteDtl.ConfigData_c, ‘~’) else ‘’ end)
I haven’t tried seeing what happens if you exceed the array length.
Joe
@hmwillett,
Thanks, that’s exactly what I needed. Didn’t even need a case statement as SO / Line / Rel have their own calculated fields. The BAQ only looks for changes to the OrderRel table, so there will always be results in each column.
@jdtrent, that’s a good idea too and I may need it for another report for Shipping and AR reports later.
If you have access to EpicCare, this is a very helpful KB article: KB0030301
