SQL 2012 and ODBC DNS Native Client 10.0
<!-- #ygrps-yiv-1977336107 _filtered #ygrps-yiv-1977336107 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1977336107 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1977336107 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-1977336107 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered #ygrps-yiv-1977336107 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-1977336107 #ygrps-yiv-1977336107 p.ygrps-yiv-1977336107MsoNormal, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107MsoNormal, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-1977336107 a:link, #ygrps-yiv-1977336107 span.ygrps-yiv-1977336107MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-1977336107 a:visited, #ygrps-yiv-1977336107 span.ygrps-yiv-1977336107MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-1977336107 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1977336107 code
font-family:“Courier New”;}
#ygrps-yiv-1977336107 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-1977336107 tt
#ygrps-yiv-1977336107 span.ygrps-yiv-1977336107cat
#ygrps-yiv-1977336107 span.ygrps-yiv-1977336107ct
#ygrps-yiv-1977336107 span.ygrps-yiv-1977336107HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107attach, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107attach, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107bold, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107bold, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107green, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107green, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107replbq, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107replbq, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107ad, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107ad, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107underline, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107underline, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1977336107 span.ygrps-yiv-1977336107yshortcuts
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107ad1, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107ad1, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107ad2, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107ad2, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1977336107 p.ygrps-yiv-1977336107underline1, #ygrps-yiv-1977336107 li.ygrps-yiv-1977336107underline1, #ygrps-yiv-1977336107 div.ygrps-yiv-1977336107underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1977336107 span.ygrps-yiv-1977336107yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-1977336107 span.ygrps-yiv-1977336107yshortcuts2
font-weight:normal;}
#ygrps-yiv-1977336107 span.ygrps-yiv-1977336107EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-1977336107 .ygrps-yiv-1977336107MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1977336107 div.ygrps-yiv-1977336107WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-1977336107 ol
{margin-bottom:0in;}
#ygrps-yiv-1977336107 ul
We are running SQL 2012. Which OLEDB SQL server driver should be used? Epicor suggested running Native Client 10 but it doesn’t correspond to our SQL 2012 version.
SQL 2008R2 = SQL Server Native Client 10.0
SQL 2012 = SQL Server Native Client 11.0
Please Note:  After a little research, “SQL Server Native Client 11.0” is also used with SQL 2014 & 2016.
Based off the current version of “SQL Server Native Client”, it is recommended that you upgrade to 11.0 to match the SQL version you are running.
