Hi,
My finance department asked for excel spreedsheet imitating the method tracer and cost workbench. Basiclly they want a flat table showing all components for top level part. I am in the progreess of creating the query but I would already like to know how to pass a value from field to query in excel as a parameter. When I use the query with “declare” excel is not recognizing it as a parameter. When I tried to use Microsot Query editor and just paste my query with adding the ? it has an issue with graphic presentation and cannot find the tables ( seems like it does not like the syntax).
Did you ever mangage to achive something like this? Should I save it as a stored procedure and then use it in excel?
Thank you
Aleksander
declare @TopPart nvarchar(20) = ‘396-00FDP-4600’
select PartNum_L1, RevNum_L1, MtlSeq_L1, MtlPartNum_L1, PartDesc_L1, TypeCode_L1, BOML_L1, PartNum_L2, RevNum_L2, MtlSeq_L2, MtlPartNum_L2, TypeCode_L2, BOML_L2, PartNum_L3, RevNum_L3, MtlSeq_L3, MtlPartNum_L3, TypeCode_L3, BOML_L3, PartNum_L4, RevNum_L4, MtlSeq_L4, MtlPartNum_L4, TypeCode_L4, BOML_L4,PartNum_L5, RevNum_L5, MtlSeq_L5, MtlPartNum_L5, TypeCode_L5, BOML_L5, PartNum_L6, RevNum_L6, MtlSeq_L6, MtlPartNum_L6, TypeCode_L6, BOML_L6, x.PartNum as PartNum_L7, x.RevisionNum as RevNum_L7, x.MtlSeq as MtlSeq_L7, x.MtlPartNum as MtlPartNum_L7, Part.TypeCode as TypeCode_L7, BOML_L7 = 7 from
(select PartNum_L1, RevNum_L1, MtlSeq_L1, MtlPartNum_L1, PartDesc_L1, TypeCode_L1, BOML_L1, PartNum_L2, RevNum_L2, MtlSeq_L2, MtlPartNum_L2, TypeCode_L2, BOML_L2, PartNum_L3, RevNum_L3, MtlSeq_L3, MtlPartNum_L3, TypeCode_L3, BOML_L3, PartNum_L4, RevNum_L4, MtlSeq_L4, MtlPartNum_L4, TypeCode_L4, BOML_L4,PartNum_L5, RevNum_L5, MtlSeq_L5, MtlPartNum_L5, TypeCode_L5, BOML_L5, x.PartNum as PartNum_L6, x.RevisionNum as RevNum_L6, x.MtlSeq as MtlSeq_L6, x.MtlPartNum as MtlPartNum_L6, Part.TypeCode as TypeCode_L6, BOML_L6 = 6 from
(select PartNum_L1, RevNum_L1, MtlSeq_L1, MtlPartNum_L1, PartDesc_L1, TypeCode_L1, BOML_L1, PartNum_L2, RevNum_L2, MtlSeq_L2, MtlPartNum_L2, TypeCode_L2, BOML_L2, PartNum_L3, RevNum_L3, MtlSeq_L3, MtlPartNum_L3, TypeCode_L3, BOML_L3, PartNum_L4, RevNum_L4, MtlSeq_L4, MtlPartNum_L4, TypeCode_L4, BOML_L4,x.PartNum as PartNum_L5, x.RevisionNum as RevNum_L5, x.MtlSeq as MtlSeq_L5, x.MtlPartNum as MtlPartNum_L5, Part.TypeCode as TypeCode_L5, BOML_L5 = 5 from
(select PartNum_L1, RevNum_L1, MtlSeq_L1, MtlPartNum_L1, PartDesc_L1, TypeCode_L1, BOML_L1, PartNum_L2, RevNum_L2, MtlSeq_L2, MtlPartNum_L2, TypeCode_L2, BOML_L2, PartNum_L3, RevNum_L3, MtlSeq_L3, MtlPartNum_L3, TypeCode_L3, BOML_L3, x.PartNum as PartNum_L4, x.RevisionNum as RevNum_L4, x.MtlSeq as MtlSeq_L4, x.MtlPartNum as MtlPartNum_L4, Part.TypeCode as TypeCode_L4, BOML_L4 = 4
from (select Level2.PartNum_Level1 as PartNum_L1,Level2.RevisionNum_Level1 as RevNum_L1,Level2.MtlSeq_Level1 as MtlSeq_L1,Level2.MtlPartNum_Level1 as MtlPartNum_L1,Level2.PartDescription_Level1 as PartDesc_L1,Level2.TypeCode_Level1 as TypeCode_L1,Level2.BOMLevel_Level1 as BOML_L1,Level2.PartNum_Level2 as PartNum_L2,Level2.RevisionNum_Level2 as RevNum_L2,Level2.MtlSeq_Level2 as MtlSeq_L2,Level2.MtlPartNum_Level2 as MtlPartNum_L2,Level2.TypeCode_Level2 as TypeCode_L2,Level2.BOMLevel_Level2 as BOML_L2, x.PartNum as PartNum_L3, x.RevisionNum as RevNum_L3, x.MtlSeq as MtlSeq_L3, x.MtlPartNum as MtlPartNum_L3, Part.TypeCode as TypeCode_L3, BOML_L3 = 3 from
(select Level1.PartNum as PartNum_Level1, Level1.RevisionNum as RevisionNum_Level1, Level1.MtlSeq as MtlSeq_Level1, Level1.MtlPartNum as MtlPartNum_Level1, Level1.PartDescription as PartDescription_Level1,
Level1.TypeCode as TypeCode_Level1, Level1.BOMLevel as BOMLevel_Level1, x.PartNum as PartNum_Level2, x.RevisionNum as RevisionNum_Level2, x.MtlSeq as MtlSeq_Level2, x.MtlPartNum as MtlPartNum_Level2, Part.TypeCode as TypeCode_Level2, BOMLevel_Level2 = 2 from (select PartMtl.PartNum, PartMtl.RevisionNum, PartRev.Approved, PartMtl.MtlSeq, PartMtl.MtlPartNum, Part.PartDescription, Part.TypeCode, BOMLevel = 1
from erp.PartMtl join erp.PartRev on PartMtl.PartNum = @TopPart and PartRev.Approved = 1 and PartMtl.PartNum = PartRev.PartNum and PartMtl.RevisionNum = PartRev.RevisionNum
join erp.Part on PartMtl.MtlPartNum = Part.PartNum) as Level1
left join (select PartMtl.PartNum, PartMtl.RevisionNum, PartRev.Approved, PartMtl.MtlSeq, PartMtl.MtlPartNum from erp.PartMtl
join erp.PartRev on PartRev.Approved = 1 and PartMtl.PartNum = PartRev.PartNum and PartMtl.RevisionNum = PartRev.RevisionNum) as x on Level1.MtlPartNum = x.PartNum
left join erp.Part on x.MtlPartNum = Part.PartNum) as Level2
left join
join erp.PartRev on PartRev.Approved = 1 and PartMtl.PartNum = PartRev.PartNum and PartMtl.RevisionNum = PartRev.RevisionNum) as x on Level2.MtlPartNum_Level2 = x.PartNum
left join erp.Part on x.MtlPartNum = Part.PartNum) as Level3
join erp.PartRev on PartRev.Approved = 1 and PartMtl.PartNum = PartRev.PartNum and PartMtl.RevisionNum = PartRev.RevisionNum) as x on Level3.MtlPartNum_L3 = x.PartNum
left join erp.Part on x.MtlPartNum = Part.PartNum) as Level4
join erp.PartRev on PartRev.Approved = 1 and PartMtl.PartNum = PartRev.PartNum and PartMtl.RevisionNum = PartRev.RevisionNum) as x on Level4.MtlPartNum_L4 = x.PartNum
left join erp.Part on x.MtlPartNum = Part.PartNum) as Level5
join erp.PartRev on PartRev.Approved = 1 and PartMtl.PartNum = PartRev.PartNum and PartMtl.RevisionNum = PartRev.RevisionNum) as x on Level5.MtlPartNum_L5 = x.PartNum
left join erp.Part on x.MtlPartNum = Part.PartNum) as Level6
join erp.PartRev on PartRev.Approved = 1 and PartMtl.PartNum = PartRev.PartNum and PartMtl.RevisionNum = PartRev.RevisionNum) as x on Level6.MtlPartNum_L6 = x.PartNum
